Up In The Air Or On The Ground???
Hello folks,
recently I've been scouting potential spots in the mountians to stay over the weekend in. Which is when I found this perfect, flat, open area tucked down in a valley with a fairly deep creek that I fell in, about 25 yards away. Now I've slept on the ground before using a wool blanket and a tarp underneath and sleeping in my Teton 20 degree sleeping bag. It was fine, but I was wondering if the advantages of sleeping in a hammock is something that I should consider?
Pertaining to both the site in the bottom of a valley in winter and to the elevated hammock, consider that the coldest air sinks thus the bottom of the valley near the creek will be colder than a bench further up and the bag at ground level will be colder than one slightly elevated, even by a hammock.
^^^^Just what Codger said. Don't sleep at the bottom of the valley.
Also It wouldn't hurt to have more insulation underneath you, even in a hammock. On the ground you can add a closed cell foam mattress or cut some pine bows and pay them under your tarp/blanket ground cloth set up.
In a hammock you will basically be surrounded by cold air because you are suspended. You will need insulation between you and the hammock.
I probably won't camp there until March or April be cause im not really outfitted for winter camping.
Cool. Just remember that the same phenomenon applies year round. A night at 50 or 60 degrees on a hillside can be a night at 40 or below in a valley. As the sun rises in the morning the cold air above will fall like a stone, somewhat down the slope but more so down a watercourse at the bottom of a valley. I learned this the hard way over the years with my canoe camping. It can be useful during hot weather where cooler air is welcomed.
its all personal preference. You can sleep comfortably with both but just need different gear for each.
Hammock camping in cool weather takes special gear considerations and some experience to be comfortably warm.
Sleeping bag insulation under a persons weight will be useless compressed by the hammock. Foam pads will help if they're wide enough around the shoulders/arms. Some folks cut up pads and tape them together for custom sizes/shapes. A quilt made specifically for hanging outside the underneath of a hammock is the best way, then another quilt or bag inside.
A tarp big enough to reach the ground on all sides to block wind will help a lot. Hanging in the open breeze gets cold fast.
Hammock camping in general might not be comfortable for everyone. It's best to have a few practice hangs in the backyard or someplace with a back-up plan if the hammock doesn't work out. Especially true for colder weather hammocking. Some research will show what's available for hammock camping, warm and cool temperatures, and a few trial runs will help a lot.
With a flat campsite already picked out, I'd chose a tent for mountain weather. Being comfortably warm in a hammock will take more gear and figuring than a tent.
