- Aug 26, 2005
O:K: Drawknife edge has been brought back far enough to be useable . On poplar it will sometimes lift toothpick sized splinters . Is this a common issue with poplar , my technique or perhaps a fault in the edge profile I put on ?
I am also using my rasps as Codger64 suggested . The farriers is way too aggressive . I have a smaller Nicholsons trhat is just the trick for taking down any ridges or smooth out valleys .
I have the hawk handle well shaped out except for the last three inches . I fit the head on thump it into place and look along the bottom or top edges for tight places to shave and loose places to avoid . I then outline these places with a pencil and shave away the pencil lines . I also look where the head was and look for any rubbed spots that indicate a slightly high spot to file/sand down .
It seems to me that there is a little something I am not picking up on . As I progress the head progresses up the shaft . It doesn,t seem to be taper fitting as well as it should . Can you see something I could improve in my technique ?
I enjoy using the drawknife on the poplar it almost feels like I am sculpting something out of clay . A satisfying feeling .
