- Aug 26, 2005
Thanks to a couple of Ddeans posts and other advice I have been making satisfactory progress on my bamboo arrows . Taking the best of home depot
garden stakes I straighten them out by heating the nodes over a hot plate element and aligning the sections in that manner . There is a fine line between pliable and scorched . I am going to try and invert an iron griddle I have over the element and roll a hot iron over the nodes . I hope that the griddles even distribution of heat along with the irons pressure and heat will allow me to keep the heat down a bit and so prevent scorching . I am concerned that the iron will slip on the node instead of rolling it . If I can get this procedure down it will have the added effect of flattening the node to some degree which makes for a prettier arrow .
I would also like to devise an all steel roller . If you are familiar with the conveyor rollers in grocery stores ? About two feet wide by one inch steel rollers convey the boxes from one place to the other . I want two rollers as close to each other as possible . They would have to beat least halved in diameter so the bamboo aligned between them would stick up 1/16th to 3/64ths above the circumference of the rollers . I could then roll my hot iron
over the bamboo and hopefully the rollers would allow the bamboo to roll between them . If not I can manipulate the end of the bamboo shaft so as to make it roll . If this assembly is about six inches long it could sit on top of the iron plate over the element and so keep the bamboo at the proper temperature .
Does anyone know of a set-up I could modify or parts I could aquire to make this set-up ? It has to be all steel or at least heat resistant .
I am almost at the stage where my arrows are pretty enough to photograph .
If I get through this stage I promise a couple of pics .
