- Oct 20, 2021
I bought a 24" Tramontina with a poly handle. I was under the impression that the tip to somewhere around the belly would be, mostly, unfinished, but maybe that's the basic 18" Trams. I know my Ontario (18") took ages to get going with a file.
But I received it with the belly and tip oddly sharpened and, judging by the coloration, possibly overheated enough to to ruin the temper on the edge of the tip. I can't tell if the seller did it or if it came from the factory like this. If the seller didn't do it, did the factory sharpen it before or after heat treating it? Should I return it and/or leave a bad review?
These two show the burn:
These last two show the light reflecting off an additional two bevels from improper sharpening:
I could care less about it being improperly sharpened, the tip being damaged and the burn mark. I was gonna hit with a mill file anyway. The last 9 inches of the blade weren't true, but it was easily fixed. What does worry me is that the temper on the edge of that portion of the tip may have been ruined.
I got it for clearing certain sections of grassy weeds so I wouldn't have to get so close or low. Imagine dense Johnson grass and Itchgrass type invasive weeds with half inch thick brambles and worse growing in, on and around it.(Welcome to Texas!
) So the tip will definitely be dragging accross vegetation every swing even though I only intend to cut with the sweet spot.
