I have been using my kitchen oven for tempering the few blades I have made. Recently I read about how much kitchen ovens can vary in temp., so the search continued for a reliable/consistent source for tempering heat. Then i found a toaster oven and put it to the test with my thermocouple. it maintained an even temp for about 15 minutes, then continued to drop temperature by cycling shorter and shorter. it finally settled around 360 degrees, no matter what i turned the temp dial to.
So the search continues for a consistent method for tempering. So the question so long in the making is... can you temper a carbon steel blade in an oil bath to ensure proper temperature regulation? if so, what method, tools, oils... do you use. i was thinking for smaller blades, a gas range and a pot full of olive oil and a good thermometer would work, anybody use a similar setup for tempering?
thanks
Jon
thanks
Jon
