I have been searching for a useable trout and bird knife. The current ones I see have too big a blade to be useable. In my humble opinion after 40 plus years of bird hunting, dressing a bird in the field requires a sharp, short (apprx. 3" to 3 1/2") blade with a non slip handle. The width of the blade need only be about 1/2" wide as you need to slice the bird from under the tail to the ribs in order to remove the internals witnout cutting into the intestines.. It should be a fixed handle not a folder for ease of cleaning in the field. Years back Gerber produced a reasonable trout and bird that fit the above description. It was long ago duscontinued. The Gerber did not have the feeling of pride in ownership a custom made knife offers.
I feel the same way about an intelligently chosen deer knife. That is a 4" to 4 1/2" drop point blade with a non slip handle. I see people coming into the deer woods with a knife that would scare Rambo. I sometimes wonder if they intend to drop from a tree and stab the deer to death. The way I was taught to dress a deer was to cut around the anus, pull it out slightly and tie the tube with some string to prevent feces from contaminating the meat as you continue to dress the deer. You then slit the deer from above the penis to the rib cage, taking care to cut the epidermus only and not cut into the intestines. Then you reach up into the cavity and cut above the esophagus and remove all. This can not be done with a knife that is of much size.
Forgive the rant but I really am tired of searching for the correct tools to accompany me afield.
