I have used a lot of files too,
and I don't find Nicholson files better then say Oberg, Sandvik, Facom, Valor....
They are a good grade of files, but since Nicholson makes a lot of series of files, they've been known to make crap too.
I currently use Sandvik files, and they are more consistent then Nicholson files in quality.
-Grind the teeth off before you use them, this can be done rough with an angle grinder.
-Anneal by letting them cool down slowly. I do this in a big crucible filled with very pure charcoal ashes. Leaves the blades too hot to touch even after 24 hours. If you need to really soft anneal, put a piece of hot metal by it and let it soak for a few days. I have a bar off HSS which I always use for that.
-Always oilquench, as you don't know what steel you are working with. Check hardness, and if it is not fileable, you're dealing with good steel which needs a temper.
If it is fileable, check if the lower layers of steel are fileable too, if they are, this is low carbon stuff and not suitable for knives.
greetz, Bart.
"If the world wouldn't SUCK, we'd all fall off !"
member of the BKS
http://www.expage.com/belgianknives
