User Grind Question
Recently picked up a 6" #25. Intend for this knife to be a user ... specifically for elk and big game.
The knife came with a beautiful near apple seed edge profile / grind.
Randall advertises their blades are flat ground with a 40 degree overall grind. This one looks more hollow or saber ground.
My blade has a edge profile that won't cut newsprint but will cut paper stock quite well.
My question is what have others used for a general utility grind? Have you users reprofiled your blades to a higher grind in the 20-30 degree overall range and did the blade hold that edge? Will the O-1 steel take a polish or do you recommend a toothier edge finish?
I'm an experienced freehander with bench stones and have diamod and ceramic stones to put a quality edge on this blade. Just not sure what this steel / blade can handle before rolling or chipping the edge with reasonably hard use.
Could really use some help here.
Thanks!
NJ
“The strength of an individual is not measured by how much one can control others, but by how much one can control oneself.” Hidy Ochiai
