- Mar 19, 2018
Just wandering about s35vn steel on user knives and what your experience has been in regards to their corrosion resistance. Have you used them in summer or humid conditions or in/near the ocean? How did it hold up?
That’s reassuring thanks, so does s35vn stain before it rusts?Living in south Louisiana about 30 minutes from the gulf, where the humidity in the summertime averages 80%, S35VN has not been a problem. I’m very pleased with the corrosion resistance. So far my CRK’s, ZT’s haven’t had any signs of staining.
A lot of threads mention bead blasting and corrosion would you know if bead blasting and sandblasting are the same thing? Thanks.I’ve used S35VN from ZT, Kizer, and WE quite a bit. No issues at all.
A friend of mine had light spotting on a Bestech Pterodactyl, on the bead blasted flats.
Yeah I don’t really see many threads that mention crk knives rusting so fast!I carried a CRK inkosi, in s35vn, this summer, clipped inside my waistband. Lots of typical edc tasks, opening mail, breaking down cardboard, making fuzz sticks and so forth. Usually would strop on hardwood once every week or so to maintain bragging rights sharpness.
Anyway, clipped it into my waistband and spent the day swimming in the Columbia river with it. I’d actually forgettin about it till it was time to build a fire that evening.
I had just stroped it to hair popping sharp the day before and now it was dull as a door nail.
The sharpened edge had rust along the whole length.
The next day I disassembled the knife to inspect the rest of the blade and found spots of rust near the edge of the choil.
From what I’ve read hear and elsewhere this isn’t a common occurrence, especially in a freshwater environment.
I will say, however, that that blade has a film of mineral oil on it when carried in the same environment.
That’s pretty impressive!No problems with my ZTs. I carry them as work knives during my construction work, and on the days I work with my crews, they get soaked with my salty, really acid sweat. I can cause just about any steel to rust during the summer months and the most I have seen on my 0909 after carrying it a week on site without any maintenance is a few tiny rust spots. They easily flicked off with my fingernail, so I am quite pleased.
Robert
I wouldn't say that is true in general. The main heat treatment effects that change corrosion resistance are 1) austenitizing temperature (higher is better) and 2) tempering temperature (use the low range instead of the high range). Higher austenitizing temperature usually leads to higher hardness, the choice of low vs high tempering isn't necessarily to get higher or lower hardness.I've heard with some alloys, that as the RC hardness goes up, the stain resistance goes down?
Wonder if that's true with S35VN.
Where's Larin?
