- Jul 22, 2009
Hi Folks,
Since this is my first sale post since becoming a Gold member, I'd like to ask everyone to please be patient with me and feel free to point out anything that I might be doing wrong.
Notes:
-Unless otherwise stated, all knives have been sharpened with Paper Wheels. Some of which might have a slightly uneven(not completely flat) surface on the edge, but all edges are 100% functional and should be sharper than the factory edge.
-Shipping in the CONUS only, all knives ship USPS Priority Small Flat Rate Box, Insured.
-Paypal personal only.
-My camera is low quality and I don't have much photography skills. If requested I can attempt to take a more detailed close-up photograph of a specific part of the knife in question.
-First "I'll take it" gets it.
Dozier Professional Guides Knife
I am not the original owner of this knife. When I received it I found no signs of use other than a slight patina and the faintest trace of surface rust. I have since polished the knife slightly on a buffing wheel, leaving a shiny finish on the blade. Knife is marked "Arkansas Made Dozier" on the blade and "D2" on the bottom. Includes the vertical Kydex sheathe. Asking SOLD shipped.
Cold Steel Talwar
Blade has been scuffed slightly on both sides from rubbing against the inside of the handles. Could be possible to buff off, but that could be difficult to do without buffing off the print on the blade(bead blasting would make it more resistant to scratching). Titanium bolster has also be scuffed a little from pocket carry. Edge has been stropped on diamond paste, but the factory grind lines are still clearly visible. This has not been seriously sharpened or used, just carried.
Note:
Sometimes when waving the knife open, the lock may not fully engage. I don't know if this is a design flaw or a defect. However, the blade will always lock up when manually opening. Tension of the lock seems abnormally high, making one-handed opening extremely difficult(can be done if you have a strong thumb). Two-handed opening is not a problem.
Asking $300$270$250 shipped.
Benchmade 635 Mini-Skirmish
I am not the original owner of this knife. There is a single scratch line on one side of the blade from the last owner's attempt at sharpening, it is barely visible and will not show up in photos(requires a good light up close in order to spot). Clip side of the handle has some scratch marks on the lockbar, clip has some black spots that won't come off(could be either rust or something else, but it should be possible to buff off). Non-clip side has a shiny scuff mark near the pivot screw. Lockup is at about 70%. Asking $220$200$190 shipped.
Benchmade 755 MPR
I am not the original owner of this knife. Some scuff and scratch marks on the titanium side and clip. Asking SPF shipped.
Emerson CQC Super-7BW
Coating has been worn off on the wave opener. Lockup is at about 60%. Tip chipped off and was reground. Also ground away the second tip giving it a sort of "Spanto" style grind. Asking $150$145$140 shipped.
Emerson Super Karambit
Lockup is at about 50%. Clip has been moved for right side reverse grip.
Note:
Backbevel has been slightly mirror polished, but not the rest of the blade, so it looks somewhat inconsistent. The flat side of the blade is also somewhat similar, with a mostly stonewashed finish and then a small portion that is mirror finished near the edge from the paper wheels.
Asking $190$180 shipped.
Notes:
Cold Steel Talwar
Note:
Benchmade 755 MPR
Note:
