- Jun 26, 2009
I had always believed that the Chakma can be used to also start a fire apart from fix some curls on the edge of the Khukuri. Is this correct? If yes, then how can one start a small fire using a chakma?
I don't see how. It's a piece of steel.
Steel + flint = spark
I have a Swedish Firesteel as well. The magnesium sparks are a challenge to light all but super dry, fine tinder.
Dryer lint works very well as well, although I have ignited fine cedar bark shavings with my firesteel. But as you'd expect, starting a fire with a spark isn't as easy as using a match or a cigarette lighter and so you need to start with something very dry and fine. And also in response to some other comments, thats right, firesteels are not magnesium. As I recall reading on the internet somewhere they are ferrocerium, that being some kind of alloy. Iron and magnesium I believe. If used properly they can do more that just create sparks, you can get tiny molten balls of very hot metal. I carry a bar of magnesium also for shavings. Get yourself a good tinder ball, shave some magnesium into it, shower some sparks off a good firesteel into it, and if you don't get a fire my next recommendation is a propane torch! lolI have a Swedish Firesteel as well. The magnesium sparks are a challenge to light all but super dry, fine tinder.
I tried it on fine wood shavings, fuzz sticks and newspaper and it didn't light at all - which means with my level of survival skills, I'd be screwed.
I would be VERY curious how a chakma and flint would work in comparison...
I've used the old standby: Firesteel and cotton ball slathered with vaseline. Guaranteed ignition every time. I always carry three in an empty film canister when I'm camping.
The trouble is that you're using shavings. Those are too coarse a material for the fero rod sparks to ignite.
