I've been doing what I know some other folks here do as a general sharpening strategy: freehand on bench stones, refine your edge on Sharpmaker ceramics (the fine and ultra-fine hones), and then of course stropping.
For the folks that have been doing this a while, how do you use the Sharpmaker effectively as part of this strategy? Specifically:
* Given that you put a certain--usually unknown--edge bevel on your freehanded blade, how do you stay consistent with that bevel given that SM is pretty much limited to 2 choices (30 or 40 degrees inclusive)? Or do you just not worry about it, and assume that with the SM, you'll use say the 30-degree angle and add a micro-bevel to the existing bevel?
Note: I know how a few people do this, I think Obsessed does it this way: rather than use the SM angled holder for the hones, you clamp the knife in a vise with edge pointing up, and actually hold on to the spyderco hones by hand and run them along the edge from heel to tip, following the angle of the bevel as closely as possible. This sounds like it could work, but I wondered if anybody just uses the SM as designed, as part of their sharpening after freehanding.
