Using an inclinometer
Hello friends
I started using am inclinometer to nail the angles when sharpening, as the angles marked in the KME seems to be less than accurate, according to many instructionals. I found myself lowering the sharpener to the lowest degrees to reach standard angles, 18-20... Well this may seem obvious to you, but I was doing it wrong, as I just leaned the inclinometer on the rod and adjusted the angle. Now I lean it ON THE BLADE, zero it there and then on the rod. Obviously, the other way adjusted the absolute angle, bit the blade is not angle zero. Well, now I have some blades sharpened at 12-13 degrees. They cut like hell, though [emoji23].
Enviado desde mi iPhone utilizando Tapatalk
I zero my angle cube on the base of my kme. Then with the stone touching the apex I sit the angle cube on top of the stone holder
That's the thing. The blade and the base are not necessarily parallel. At least in my device.
When you say you're zeroing on the blade, do you mean on a flat portion or on the primary grind?
ime many knives do not have a flat part at all, and on many others, it's too small to rest an angle cube on.
True but imho it's close enough for me. Plus I seldom use my cube unless I just want to know the angle I'm sharpening a particular knife on, I usually use the sharpie method and the cube just sits in a drawer.
Ok. In my case there are up to 7 degrees depending on the blade's width. That's how I noticed. I use the cube a lot, as I have different brands stones for the KME and, if I go for the mirror finish, I want to be as accurate as possible. For a standard serviceable edge I will not use it. The sharpie method is works fine but I am too lazy to use it after every stone change, hehe.
If it's a zero grind, I rest it flat. If it's sabre grind, on the secondary grind . If it's kind of a pen blade it won't even go to the kme. And yes, sometimes it takes some effort to measure properly.
