- Aug 31, 2011
Birchwood Casey Gun Stock Sealer & Filler: I thought it was a good idea to get some of this stuff, so I bought some, and have so far used it on a few natural walnut handles. Up til then, had never used it: just the Tru Oil by itself up til recently. I figure if Sealer Filler does what it's name says, then I don't have to use as many coats of Tru-Oil. So here is what I have done recently: apply 3 coats of the Sealer Filler, then 2 or 3 of the Tru Oil. Then 3 coats of Johnson Past Wax. Results have been pretty good, except for one handle. I will report back here as I continue to use this combination. I decided to try this combination because I read a thread about how durable of a finish it makes.
Now regarding that one handle: The brass corby bolts kept discoloring the surrounding wood, as the brass sanding dust was "bleeding." The weather was really humid, so maybe I wasn't giving the Tru Oil enough time. I was giving it 24 hours, and sanding with a grey scotchbright between coats.
I am starting with a new handle right now, making the sanding slurry with the Sealer Filler. 1st coat: just rubbed it in real hard by hand. 2nd coat: just now did the 2nd coat, making a sanding slurry with 400 grit, and will just keep doing the sanding slurry repeatedly with Sealer Filler, until I am satisfied that it is good and filled. After that, I figure the Tru-Oil is more like icing on the cake, so only 2 or 3 coats of Tru Oil.
Any thoughts? Thanks.
