Recently some folks have reported that when using diamonds on softer stainless steels, the experience is like "butter", the steel is "gummy" on the stone, the diamonds will leave too deep scratches in the soft metal, etc.
I haven't done any exhaustive testing with diamonds on many types of softer stainless, but I have started testing using diamonds on a few soft stainless steels I have in folders, and kitchen knives. Two I tried this evening: 420HC (Buck's HT) as in a Buck Selkirk folder, and some Chinese 7Cr17MoV stainless in a beater S&W 602 folder that I use for practice. With both knives:
, but this is a good utilitarian edge just from working them off of coarse plates.
Pics of the S&W 602
* After the Atoma edge reprofile. You can see the high spot back near the heel, I had to go up that high on that one side to get their uneven grind back to a consistent edge bevel. At first their ground-in unintentional recurve was so bad I had trouble getting that part of the blade on the stone.
* After the DMT coarse
No grand conclusions, my test size isn't big enough.
But it does seem like diamonds worked great on these knives.
ETA: I went back later and refined on DMT EEF. That worked great too. Basically I have no plans to sharpen a lot of my softer steels on expensive diamonds and wear them out sooner than necessary. Just wanted to prove to myself whether it would work well.
- Reprofile edge to about 14-15 dps on Atoma 140
- Apex and finish on DMT coarse, no strop
Pics of the S&W 602
