Just so you will know, "J B Weld" is a brand of epoxy.
On other forums, I have seen a few guys advocate using it to "attach" sights or scope rails on a shotgun. I have an old 16ga single shot I was thinking about trying to JB Weld some rifle sights onto to use it for deer here in VA in the counties where it is shotgun only. Your opinion please???
Im always surprised at the amount of people that think some kind of glue is actually the way to fix something. Sure, if you bust the handle off yer coffee mug, break out the crazy glue, but expecting a clip to stay attached to your knife or to put your friggin sights on a barrel???
You silver solder sights. It doesnt take any longer to properly solder the sight than to prep/mix/apply/wait to cure epoxy. Matter of fact, its quicker. The drawback, if you use epoxy, is that you will be back to square one the first time you bump that sight good. This will inevitably occur when you are out in your blind and youve spotted that trophy youve been waiting on for years and in your haste to get the gun mounted, you bang the barrel during your quick draw. Ive actually seen something similar but the idiot in question JB Welded his SCOPE RINGS on. Thankfully, the failure occurred while in camp. His rifle fell over, causing the scope to part company with the barrel. The ensuing mass hysteria when everyone realized what he had done was priceless. Thats the kind of thing you never live down.
Even if you are not equipped to hard solder/braze, you should surely have (borrow?) a cheap propane torch and could at least soft solder a sight on? Silver solder is available in soft/med/hard alloys, the difference being their melting points. Its actually very simple and the only trick is mating the parts tightly, using flux and not overheating the joint. Practice on some scrap pieces of similar thickness before you tackle your gun and dont ever quench a barrel, let it air cool. Make sure you line it up correctly!
As already mentioned, drilling and tapping is the way to go for a clip, especially with dissimilar materials.
I have been tossing this idea back and forth for years, adding sights to my old single shot 16 ga to carry for deer. I have been electronics soldering for over 40 years so believe me I am about this >> far away from trying it. The thing that worries me is the steel of the barrel and possible the alloy of the sight bases. Dissimilar metals. Spending $45 for Marble Arms bases to practice on makes me a tad nervous.
I am going down to Gander tomorrow and start with new optical orange replacement front bead. Then I'll hit the range and see how it does.
...<snip>
It won't work on a pocket clip.
