Soldering is divided into two types (for knife making purposes) SOFT soldering and HARD soldering.Most soft solders flow at around 400F, hard solders at around 1100F.Soft soldering is what is done to guards and such. FORGET paste solders. Get a low temp solder that is alloyed for your purpose. Either TIX or Stay Brite are the most common ones. Get the flux made for that solder.As said start with clean (Really clean) parts that are as tight a fit as you can make. Solder is not a filler,so avoid large gaps.Clean everything with denatured alcohol prior to soldering.Here is a guard soldering primer:
After setting the guard in position, place the blade in a vise (pad the jaws if needed) with the tang upward.Apply a liberal amount of flux around the joint area. Wipe excess flux from blade where it runs down.Take a torch with a SMALL flame. Those rechargeable butane "hobby" jobs are perfect.THE ENEMY OF A GOOD SOLDER JOB IS TOO MUCH HEAT!!. Heat slowly from the blade side of the guard. heating the guard and blade evenly.As the flux runs and bubbles start wiping the end of a piece of solder along the joint when it starts melting remove heat from the blade.apply a small amount of additional flux to the joint, reapply heat and start wiping the joint with the solder. As you wipe the solder along the joint it should flow smoothly and run along the joint. Use only a small amount of solder.Once some has flown along the joint stop adding more solder. Use a solder pick (Sharpened 1/8" brass rod ) to scrape along the joint and make the solder run smoothly.The heat is removed whenever the solder is flowing, and only reapplied when it starts to harden.Let cool down for a minute or two. Take the blade out of the vise and put a coil spring on the tang. Place the tang in the vise with the spring slightly compressed against the guard back. Look at the solder joint at the ricasso.If it is smooth and shiny, you did good. If it has gaps or is blobbed with solder that tells you there was not a clean joint, too much heat, too much solder, etc. Apply flux.Take the flame and slowly bring the joint up to the flow point again,running the solder pick along the joint to flow smoothly around.Wipe off excess solder with a damp paper towel while it is liquid.Try to avoid adding solder from the blade side .With experience you will be able to do the whole job from the blade up position, applying the solder from the tang side and drawing it up through the joint. A thing to remember is that SOLDER FLOWS TOWARD THE HEAT SOURCE.Once cooled off wash and clean all flux from the blade.To clean up the joint make a small chisel from a piece of brass or bronze and cut the excess from the joint in smooth slices. Don't use a hardened tool like a knife blade as it will scratch the blade.Fine sand paper and buffing with a bristle wheel will remove any excess, leaving a shiny and nearly invisible joint.
There are several jigs and spring tricks that you can use to hold the guard in place, but nothing works better than a good fit that has to be tapped into place.
Hope this helps.
Stacy
