Using water stones to sharpen N690 steel?
Hello all,
Just wondering if anyone has any experience using natural water stones to sharpen n690? I usually am a 1095 guy, but I am looking to try out a stainless steel blade from Boker arbolito and was wondering if I would need to purchase a modern synthetic stone?
Hello all,
you brought an almost 12 year old thread back to life. you can just start a new thread.
i use diamond benchstones on most steels nowadays. i wont go back to natural stones. worth a look if ya havent tried them yet.
  • Like
Reactions: Mo2
I have heard great things about diamond stones but I just put money into a nice set of arkansa stones and was just hoping to not have to buy another sharpening system.
Might be a little marginal, with Arkansas stones. N690 is roughly similar in composition to 440C, with about ~ 1% carbon and ~ 17% chromium. Other similarities to VG-10 as well, with molybdenum and cobalt in the alloy. Heavier grinding may be difficult (VERY slow) on Arkansas stones, although they might work OK at the finer end for finishing up.
I'd suggest a simple two-sided Coarse/Fine SiC or AlOx oilstone for the heavier work, like reprofiling, edge repair, etc. After setting the edge and doing most of the burr cleanup with the fine side of that stone, the Arkansas stones might contribute some more refinement (finer finish & polish) at the high end. With that being said, the same carbide content that makes grinding slow at the start, will also (at least somewhat) impede better results at the refining end. Man-made (synthetic) AlOx or SiC stones will always cut such steels more effectively, and would be my preference for a 440C/VG-10-class steel. Decent stones of this type will run $15-$25 or so, in an 8" bench-sized version (Norton 'Crystolon' for SiC, and Norton 'India' for AlOx, for example). Not too much extra money spent, for the better results afforded by them.
Consider that many 'tri-stone' sharpening setups featuring Arkansas stones usually include a relatively coarse SiC or AlOx oil stone as the first stage; it's there for good reason.
David
Ehh, just do it and find out. It's not like N690 is an extreme steel or anything. Just would take more time the simple carbon steels. If you were asking about something "Powdered" with lots of Vanadium that's a different story.
N690 sharpens really easy for me. I suspect most stones will work. Never tried most Arkansas stones so I can't comment on that type for the steel.
I like it much better than 440c which might be strange. But I noticed a difference.
Thanks for the info I am going to give it a go and see what happens on the natural stones first
  • Like
Reactions: Mo2
