- Dec 30, 2008
I've only used a v edge. How does the chisel edge perform? I'm wondering why all the Emerson's have a chisel if the majority of knives have a V.
- Emerson's WebsiteThere are several reasons for the chisel grind. For any of you who have ever used a correctly sharpened wood chisel for woodworking, you know what a chisel can do. Although a knife is not a chisel, those properties, when applied to a knife grind have almost magical effect. A chisel ground knife, being beveled, (ground) on one side only, possesses greater strength, (due to increased cross sectional mass) and they cut with an ease not found on any other type of blade. This is because there is no parasitic drag produced by the flat side when cutting — no drag points. On top of that, they are much easier to sharpen — you only have to sharpen one side
I don't notice any difference between they way they cut and the way my Spydercos and Benchmades cut
I mainly use my knife in my left hand. I had heard that type of edge would be perfect for me. That first three days I didn't like it much. But that fourth day I held the knife at a flatter angle and now I love it.
For me at least that slight changing of the angle of the cut (a little whittling) made all the difference in the world. I am now a believer of the chisel grind of The7.![]()
Are you a Southpaw by nature, or do you just use a knife in you wrong hand. Wrong handed is what righties some times call Southpaws.
I find the chisel grind edge very easy to maintain and sharpen. Surprised more manufacturers don't use the chisel grind.
Man, I hope I never do that again. I don't drink alcohol so i cannot use that as an excuse.I bet you^ won't do that again.
The same happened to me with a Hartsfield. I was drink'n though.
- If you take the CQC-7 as an example, it has a secondary bevel. A zero grind would not have that secondary bevel.Care to share anything on the zero ground? I just heard that term in reading this group. I take it a chisel grind isn't a "zero ground"?
http://www.spyderco.com/edge-u-cation/knifeanatomy.php
Zero Grind
That's a CQC-5. I probably should have labeled the picture.Don't even look like a CQC-7 after pimping.
