nozh2002
BANNED
- Jun 9, 2003
As I understand this purification technology in combination what Russian use for 100x18MSHD steel. Is this technology used in US for knife steels - like 440C which is similar by composition to 100x18MSHD? I know that Hitach in Yasuki adopted it but not sure that they use it for their knife steels.
From http://www.rosarmsusa.com/design.htm
The application of 110x18M steel grade
When dealing with precision bearings employed in mission-critical systems where they have to operate without lubrication under high temperature conditions in corrosive mediums, one needs to use a metal of a special chemical composition and as free as possible of nonmetallic inclusions. The research of 1966 ascertained that 110x18M steel grade is the one to meet all requirements. To decrease the content of nonmetallic inclusions, vacuum-arc remelting (VAR) was suggested.
Point analysis of maximal nonmetallic inclusion content
Nitrides Oxides
Conventional remelting 4 points 4 points
Electroslag remelting (ESR) 2 points 2 points
Vacuum-arc remelting (VAR) 1 point 0.5 - 1.0 points
Metals undergoing double remelting (ESR + VAR) have half as many nonmetallic inclusions as compared with ESR plus a reduced gas component. The metal density is greather than when applying ESR alone. Thanks to that we have better plastic properties, improved polishabiliti, and good strength characteristics. Milled carbides help to grind the blade's edge and keep it constantly sharp.
All the above factors prolong the bearing service life.
Electroslag remelting process (ESR) is an arcless process of remelting a metal electrode in a flux bath. Electrofluxed metal is noted for its premium quality, lower impurity and gas content, improved micro- and macrostructure, lower anisotrophy (directional property), twice as high mechanical properties, two up to five times more reduced nonmetallic inclusion content (such as oxides, sulphides, globules), higher wear-resistance and contact resistance, plus minor improvment of other characteristics. Electrofluxed metal is used in the production of steels and alloys for defense industry and aircraft industry. Warranty assurance is twenty years.
Any comments?
Thanks, Vassili.
Nitrides Oxides
Any comments?
Thanks, Vassili.
