- Sep 23, 1999
Just wanted to show you folks how I made a vacuum vessel/chamber for handle material stabilizing. It was cheap and easy to make and works great. I took a steel fire extinguisher tank (you can find for next to nothing at most scrap metal places)and cut the nozzle end off it and ground it as square and flat as I could. Then I took two pieces of plate and drilled 4 holes for 3/8" all thread.Bolt the all thread to thebottom plate. Drill a hole in the center of the top plate and silver solder a brass hose fitting in it. Get an old inner tube and cut a couple pieces large enough to cover one side of the top plate. I used daps weldwood contact cement and glued the two pieces of inner tube onto the plate. They need to be as flat as possible so I took a roller and worked the bubbles out. I bought a set of vacuum gauges at Lowes and vacuum pump off ebay. Just fill the tank and put the wood in, bolt the top plate on and vacuum away.
I use minwax polyurethane cut with lacquer thinner for the solution and fill the tank about 3/4 full. You can do alot of wood at a time with this outfit. I left some burl maple in it for 2 weeks and it came out great. Wish I could rig a small window in the top so I can watch the air bubbles in the solution but since I haven't, I just run the pump for 10 or 15 minutes at a time. Heres a pic.
<img src=http://members.aol.com/l6steel/vacuum.jpg>
