johnniet
- Jul 12, 1999
I got the Vagabond this week in Frank K's Pacific Salt and Vagabond passaround.
The vagabond is described as a light fixed blade, able to take a lot of abuse, suitable for picnics or backpacking. The gimmick is the self-contained sheath that flips back into the handle when the blade is in use.
The sheath works. It even has a little spring action that brings it to the blade when you get it close enough. It also slides inconspicuously into the handle, which is very comfortable with the sheath tucked inside.
The Vagabond came extremely sharp, and made very clean cuts in chocolate and smoked salmon. The hollow grind means that it can get away with a thick spine (4mm) and still cut very well, as long as it doesn't have to cut very deep.
I very much appreciate the idea behind this. I like fixed blades. The handle is at a comfortable, ergonomic angle to the blade. And I certainly like the design of a short blade with a longer handle.
But I have a couple of quibbles that will probably keep it from being my picnic knife, at least in the current version. The sheath has two small flares on it that let you pull it out of the handle when you close the knife. These flares are pretty close to the pivot, so they don't provide a lot of leverage, and it's a little tricky to pull the sheath out of the handle. I'd rather have the flares close to the tip, so they would provide more leverage. This is nitpicky, since it isn't really a problem in use.
The more serious problem I have is with the thick spine and hollow grind. The Vagabond doesn't cut as well through bread or other things that are thicker than the width of the blade. So for now I prefer an Opinel, or a Spyderco kitchen knife with some kind of sheath.
On the other hand, if I had to pick a knife to pass around to a lot of non-knifers, expecting abuse, I might want to give out the Vagabond instead. It seems very robust, and should be easy to resharpen if needed.
I like this design, and I'm looking forward to seeing more models with a similar concept.
