Hi there,
I have a Cold Steel Black Bear Classic, made of AUS-8A steel. It came dull out of the box, very disappointing...
I have a Spyderco Sharpmaker with the optional diamond honing rods.
I thought I'd reprofile the knife, using the diamond hones, on a 30 degree angle. I've used the Sharpmaker succesfully for smaller jobs but even with the diamond rods, I don't seem to get an adequate edge, I will barely shave. I have done at least 50 swipes on each side, using moderate pressure... I can see the metal particles falling from the knife... they accumulate, covering the plastic of the 204... not very thick but still...
I have done the magic-marker trick and the ink dissappears. However, the bevels were not the same width to start from and still are not. Is that normal/acceptable for a brandnew knife?
Am I not patient enough for a knife of that size? Should I just calmly keep swiping untill I have a decent edge? I thought AUS-8A was rather "sharpenable"...
I am scared ending up with a dull blade, no matter how long I try and that I will wear out my expensive diamond hones. I think I will have it done by a pro and abandon Cold Steel... *grmbl*
Thanks
Thanks
