I'm thinking about removing the coating from my force pro. What chemical solution do you think will do the best job?
Just curious, is the coating on your knife scratching up? Is that why you want to remove it. I'm asking because from what I've read, the coating on these knives is supposed to be very well done and durable. Thanks.
No lock problems on any of the dozen or so that I own and only one or two off center. Not one in the bunch is/was off center enough to be any problem unless you are just anal about it.
This is how I fixed the Force Avid scale problem.
Sounds like a good reason to consider buying the new 2012 versions that are satin-finished to me.
