The type of lock is called a liner lock. When the blade is opened part it the liner snaps against the blade. To close you push against th liner and the blade will close. It very easy to open and close with one hand. A Great Knife for sure.
My experience is different. Maybe I just got a bummer, but I had to rework and rebuild my Vantage to get it to lock up at all. The blade was way off center and won't lock up when opened at all. After much adjustment of the pivot to center up the blade and a little playing, it finally will lock up if given a "hard" opening; not so well with a soft opening. Also, more importantly the detent is almost non-existant. The blade will open just giving the closed knife a sharp shake. I got the Vantage select, so maybe the pro is better??
