Vargo TI woodburning camp stove
Codger_64
Moderator
Does anyone own and use one? Pros and cons? I am sorely tempted to get one, but wonder if I would be better off waiting until I can afford one of the dual-container "gassification" stoves. I'm not sure they would be worth the price difference to me.
http://www.vargooutdoors.com/Titanium-Hexagon-Backpacking-Wood-Stove
I have this stove. It is light and very compact when folded. Since it is so small you have to constantly feed small twigs, etc. I prefer the Emberlit which now is available in titanium like the Vargo. The Emberlit is an ounce heavier but $5 cheaper in titanium. I have the stainless model at half the price and twice the weight at 11 ounces.
Uploaded with ImageShack.us
http://www.emberlit.com/
I have the emberlit too and it's awesome. I've not tried the vargo but I held it in REI the other day. It looked like it was well made but looked too small for what I wanted. I'm sure it works great. I think Rock has one too and he loves it.
The only thing the vargo had on the emberlit was that it was lighter. I am glad I didnt buy the vargo because I didnt know they made the Emberlit in titanium until the other day. Ordered one just now for less than the vargo.
I just got my Emberlit and I hope to try it out today while out in the timber. While not in use though it makes a great knife holder :eek::D
Bryan
I don't have the Vargo but I do have the Emberlit. The stove is just outstanding. I have used it with wood as well as with the trangia and love it.
Inquiry sent for mailing address. Consider the trigger pulled. I did note a wire mesh bottom screen on the website.
ETA: re-watched the vid... the harware cloth mesh is for a top support for undersized pots!
Mikhail responded to my email in less than an hour! I'll get my order placed in a day or two. mmmmm... bacon!:thumbup:
When I got mine I took some wet-dry sandpaper to round the edges. Just takes a minute. Also there was a tiny nub on the side toward the bottom that caught the tab when you wanted to disassemble it. A diamond hone took care of that.
Yeah, the site mentioned some die burrs. I can live with/fix that. A fine die to form those panels and labor to fine finish them would double the cost of that otherwise simple and inexpensive stove. I am seriously debating getting two of them for teaching my grandkids by letting them help me cook in camp. One granddaughter has never been camping before, let alone in a canoe. And a co-worker's nephew hasn't been canoe camping. It would be good exercise in small firebuilding and fire management, LNT ethics and making good meals in the rough. I don't think I could eat my bacon warm but raw like that guy did in the video though.
Yeah, Milani74 is correct. I’ve had the Vargo for a while and also have the Emberlit. The Vargo design is nice in that it is a one-piece design. The narrow top helps to concentrate heat and holds smaller diameter bottles easier. The hinged door is a neat feature, but unnecessary as once it’s open to feed, it’s a pain to open and close when it’s already burning fuel. Although not a deal-breaker, the Vargo storage pouch is a great design and something you need to consider with the Emberlit. Biggest issue with the Vargo is the holes in the bottom. You really have to be careful as to what is underneath as the hot ashes will fall through.
I really like the Emberlit design. It does come in five pieces to construct but still folds flat like the Vargo. I’m awaiting the Ti version now…titanium is not only lighter, but also cools off a lot faster when you done and need to pack up. The Emberlit is also easier to clean and is much more stable when pieced together. It does have a much larger opening at the top and that’s where a wire/mesh screen helps to hold up smaller diameter bottles. I’ve found the Emberlit easier to load with fuel and it seems to burn longer…no scientific tests, but I’m sure the slightly larger size/design helps to hold more fuel and burn longer. Also, the biggest advantage is the closed bottom…hot coals and ashes are retained in the stove. You can put the stove on more surfaces without worrying about burning them. I’m sure it gets hot, but not to point of burning. Best example was using the stove on a piece of bark over snow. The Vargo would catch that bark on fire and sink.
If you plan to really use the stove as a primary cooking stove, I would pick the Emberlit over the Vargo. If you’re not too concerned with weight, the steel version is the best value.
That ceramic tile show above cracked and broke from the heat generated off the bottom of the Vargo and hot, burning coals that fell through the bottom vent holes.
ROCK6
Thanks for the input Rock6. The points you make are mostly what had already swayed me toward the Emberlit stove over the Vargo, regardless of materials. I am just waiting for the maker to get back to me with a payment address so that I can send off my money order.
I appreciate the comments here. I was going to pick up a Vargo, but after comparing it to the Emberlit I bought the Emberlit. It has already shipped, so it should be here pretty soon.
See you already made your decsion. I have both the vargo and the emberlit. I see the vargo as a day pack kind of stove paired with a mug and maybe even an alcohol buner. Smaller ligher equally easy to use. The emberlit I've paired with a mors pot as I see it as more for trips and such or a day trip with more people. Might get the emberlit TI down the road but not very high on the list at the moment.
I just ordered the titanium version. The cost difference between it and the steel one was not much. Now for the wait. The ti version seems to pretty well stay sold out and on backorder. Hopefully there will be enough stoves in the shipment he is expecting today to fill my order. I'll just have to use my Max Micro gas stove again this coming weekend.
