Hey guys, I need some expert advice here.
I have a Coote running with a variable speed 750w motor (cap-start), with a high voltage control box and wall control. These are all components used on evaporative air-conditioners, all brand new. For the life of me I can't get the variable speed to work... It is either running at full speed, or stopped. If I switch it on with the dial on low speed, it starts slow, but any pressure on the grinding belt stops the motor. I seem to be able to turn the speed up, but once it gets to speed, I cannot turn it back down with the dial. So I figured maybe it needed back pressure right? If I apply grinding pressure, it just stops the motor if the dial is turned down to say half-way, but if it is turned up to full speed, it will keep running at that speed (ie. the pressure on the belt will not bog it down - as it shouldn't). I have had 2 electricians look at this and neither can work out why it won't work - but neither have tried this setup it on anything other than an air-conditioner.
Does anyone have any ideas which might explain why this is happening?
Thanks guys,
Steve.
Thanks guys,
Steve.
