- Dec 9, 2003
I was thinking about the various edge types in batoning and the various steel types and how some can sustain chopping and batoning well. Not so much for axes, but more large camping knives like the Busses and Ranger knives.
Then i started to think visually and it seemed that in many cases or chopping/batoning through a material that isnt too flexible that the very edge of the knife doesnt play much of a part past the initial whack. I created a diagram to illustrate my point. Yes i do realize that wood can bend some but wood will often split when you are trying to cut it lengthwise and i think the amount it bends would not be significant for the diagram/point.
Excuse the poor diagram.
It seems that once the edge goes into the wood and splits it a little bit the tip of the edge doesnt really touch the wood anymore, rather only the sides. In effect it seems that the walls of the knife are prying the wood apart by pushing outwards on both sides. As i started to look at it i noticed that some edge types were more likely to have higher drag because of more surface touching the wood. Flat grind seems to have the most potential for creating drag from the wood while a taper grind produces the least. The taper grind seems like the only drag would be at the section where the edge starts a new angle.
The red circles are meant to indicate where the knife would be touching the wood/creating drag on the knife.
So what this makes me wonder is how important is the steel really? Is it still important for the first whack?
It also make me wonder about the tests where people baton a knife through fire wood. Is the knife steel that great, or is it really just that the edge geometry of the knife keeps the sharp edge of the knife away from the wood?
Obviously a super hard or super soft steel would have problems on the initial whack though. Everyone see what im getting at though?
Thoughts?
Thoughts?
