Various W2 Heat treatment results
Thanks to HSC's help I was able to heat treat a few blanks of w2 and have them hardness tested. Heres what I did/found.
It seems to be agreed upon that at a time in the past Aldo's W2 needed a soak well above critical to harden, this may or may not still be the case.
I tested 4 pieces of Aldos current W2, batch 15092. Heat treat done with a propane forge with baffle and thermocouple. All pieces quenched in brine (60 Celcius) 3 seconds then into warm oil till cool. Immediately tempered 2 times 2 hrs each at 195 c or ~380f. All blanks hardness tested in 3 places, the results were averaged, there were no low/high outliers
Blank 1 (62.5 HRC): 1x 15-minute soak at 950 c (1742 f). followed by 1 normalization cycle at 4 reducing temperatures with no soak, air-cooled to black, 900 c (1652f), 850 c (1562f), 800 c (1472f), 750 c (1382f). Quenched at 790 c (1454f) on a rising heat no soak. took 2 minutes to reach heat.
Blank 2 (60.5 HRC): 1x 15-minute soak at 950 c (1742 f). followed by 1 normalization cycle at 4 reducing temperatures with no soak, air-cooled to black, 900 c (1652f), 850 c (1562f), 800 c (1472f), 750 c (1382f). Held at 790 (1454f) for a 5-minute soak then quenched.
Blank 3 (50.5 HRC): No thermal cycling. Steel straight as it came from Aldo. Quenched at 790 c (1454f) on a rising heat no soak. took 2 minutes to reach heat.
Blank 4 (61.5 HRC): No thermal cycling. Steel straight as it came from Aldo. Held at 790 (1454f) for a 5-minute soak then quenched.
It was no surprise that blank 3 was so soft. I'm confident there just wasn't enough time at heat to get the carbides into solution. I've personally been using method 1 from research and recommendations found on the forums. However, it is surprising to see sample 4 test so high. Maybe the steel is in good condition from the mill to heat treat.
I figure I'll let the people here more educated than I weigh-in and draw further conclusions.
Edit: added freedom units
Thanks for the info. I don't currently have planned any W2 in the near future, but I'll keep this as a reference. One of the problems I have with specs like W2 or 1095 is how wide the composition tolerances are. That means that you have to assume you'll have variances from batch to batch, and that complicates comparison, or even spotting errors.
This is America, please use Fahrenheit.
Some of us work in celcius, even in america. But to be honest I think you'll find that the most experienced members of the forum are more likely to work in farenheit and less likely to take the time to do conversions to share their experiences.
Way back, I talked to Dr Verhoeven quite a bit but when we talked, we had to keep converting from celsius to Fahrenheit and back in order to understand each other.
Hoss
