- Jun 16, 2003
Vaughn's "all steel" BSa Axe dates back to 1940. Is this wooden-handled axe even older?
Is there Vaughan maker's mark on the head?Vaughn's "all steel" BSa Axe dates back to 1940. Is the wooden-handles axe even older?
Thank you for your interest.
The axe with an original 28" haft was sold by BSA FROM 1936-1940 as a "Felling Axe." It was said to have a "bi-metallic" head. https://books.google.com/books?id=7aoTAQAAMAAJ&pg=RA2-PA72&lpg=RA2-PA72&dq="vaughan+&+bushnell"+axes+"bi-metallic"&source=bl&ots=4wBewteqqz&sig=ACfU3U23KzfcfMIXqiO3UYZfLXpMfChjDw&hl=en&sa=X&ved=2ahUKEwit7-zpwMztAhXEZc0KHbdiCpQQ6AEwAHoECAEQAg#v=onepage&q="vaughan & bushnell" axes "bi-metallic"&f=false
The hand axe I am wondering about, the one with a wood handle ("cream with red tip") with the BSA seal and legend "Official Scout Axe," also is sold as having a "bi-metallic" head. I bought mine on eBay for $5.00 in 2007 Never tracked down its dates of production.
Found this in a 1940 Vaughn & Bushnell catalog:
"VAUGHAN AXES
Vaughan Axes are manufactured under the PATENTED ELECTRIC FUSION PROCESS (Pats. 1,948,548 and
1,948,549). This consists of forging the head and blade of the axe separately, the two being joined together by
the ELECTRIC FUSION PROCESS, a picture of which may be seen on the opposite page. This produces a per-
fect blend of the two parts, each of which is made fromthe particular type of steel best suited for both parts
of the axe.
The head of the axe is forged from a tough steel that will withstand the most severe usage. The entire blade is
forged separately from a high grade tool steel chosenfor its cutting qualities and its ability to stand up under
the most gruelling service. The result, after being joinedtogether by the ELECTRIC FUSION PROCESS, is a
real electric bi-metallic axe that is recognized as thestrongest yet developed.
The Vaughan process of axe manufacture produces the thinnest blade for faster cutting together with an eye
that is true and will stand up under the hardest service. The all tool steel blade, extending almost to the point
where the eye begins, permits the axe to be ground backfurther, greatly increasing the life of the tool.
For faster cutting, longer life and absolute dependability,try a Vaughan Axe. Thousands of satisfied users will
vouch for them." [emphasis added]
I looked at the Boys' Life ad. I find no ad for any brand of "mono-steel head with wooden handle (#1510)." I do find an ad for a Plumb hand axe with a "forged" head, BSA # 1510 (1930-1940).
i would look a earlier copies of Boys' Life but it seems that the "Way Back Machine" is down again.
BSA marked hatchet vs Matowoc hatchet(Marion Tool)Marketing of unofficial hand axes to Scouts by Marion Tool:
https://books.google.com/books?id=bl--hWHNXtMC&pg=PA50&lpg=PA50&dq="marion+tool"+"boy+scout"+axe&source=bl&ots=n_dLUwsakm&sig=ACfU3U2jREPtYcRHdj3CWjZ47LDtMyfJEA&hl=en&sa=X&ved=2ahUKEwiSyLC1h9TtAhXKHM0KHTfGBmo4ChDoATABegQICBAC#v=onepage&q="marion tool" "boy scout" axe&f=false
