I figured out what happened - when I purchased the new Venev stones, I also purchased a Hapstone T1 guide, and started setting the bevel with the rods WAAAYY to high. I essentially blunted the edge a lot more than I thought. Today with the 30X loupe I could see the heavy scratch pattern at the very edge, polished right behind that. The actual edge probably had a 25+DPS rough, convex edge, effectively.
So this morning I started over at 240 grit, 100% freehand until I knew I had a burr along the complete edge (just feeling by fingertips). I guess my natural freehand angle is somewhere around 20dps, maybe a touch thinner. I worked it side by side to a full burr (then removing it), then again at 400 and 800 grit. At this point it was shaving arm hair easily (a vast improvement from yesterday). I then spent just a little time on the 1200 grit stone, and at that grit I cannot really feel a burr, but things looked good under the loupe. At that point I switched to a strop, black then green compound on a basic leather (rough out) strop.
This edge is now whittling hair. This is as good as I usually can achieve on a good day. To do this from scratch, freehand, on a brand new/unfamiliar set of stones is amazing (for me)!
So if you consider I had to essentially reprofile this knife because of the damage I did yesterday, I had about 30 minutes into this sharpening session from scratch. Not bad at all.
I'm now a big fan of the Venev stones!
