I don't think it's necessary at all. 240 should work fine. It's plenty coarse for the first stone. It may take a little longer if doing a reprofile but not by much.
Was just reading on the gritomatic blog a out the concentration of diamonds in the stones. As of January the #60 has the highest concentration of diamonds aka 100%. #80-240 is 50% and 25% for 400-2000. It's absolutely necessary that the 400-1000,have less concentration per gritomatic due to requiring less scratches at the finer grits. But he says every so performance doesn't change by much.Thanks for your reply, I was kind of guessing that may be the case.
It also says a good way to clean the stones is to use soapy water and an eraser or liquid surface scrub with abrasive particles. The guys on YouTube are using some high grit water stone with soap and water.
It would be worth trying rubbing alcohol as well. It works really well to remove the dark spots without removing any of the stone with resin bond stones.Was just reading on the gritomatic blog a out the concentration of diamonds in the stones. As of January the #60 has the highest concentration of diamonds aka 100%. #80-240 is 50% and 25% for 400-2000. It's absolutely necessary that the 400-1000,have less concentration per gritomatic due to requiring less scratches at the finer grits. But he says every so performance doesn't change by much.
