Be aware Brad, that it expands with heat. If you are doing 4 or 5 pieces at a time, too much in your bucket will make the last 2 pieces hard to bury. It will help soften the metal, but still cools too rapidly for a proper anneal. After a few times, I gave up and just started buying properly annealed steel from Aldo.
As stated, burying your blades in vermiculite doesn't give a true anneal, however, I've found that if I heat some large billets of mild steel to about 1500 degrees F. and bury them in the vermiculite, closely packed together and then put the hot blade in the center of them, the blade will cool much more slowly and give me a pretty good anneal. I have about 6 bars of 1-1/2" keystock that I use to preheat my vermiculite with. The preheating bars seem to have made a world of difference. I've found that my steel grinds and drills much easier when using the preheat bars in my vermiculite, because the large cross section of those preheat bars tends to hold the higher temperatures for a much longer period of time than just sticking one skinny (by comparison) blade down into the vermiculite.
On this subject, does vermiculite have superior insulating properties over perlite?.
