Version 1 1972 112 and early 112
austin37
As far as practical usage of the Orginal and early 112 versions.. was there any features less desired and later improved , that make buying such an early 112 as a daily user a not worth while purchase and they’re better as display only? I like the micarta scales on those early 112 and don’t wanna spend the hundreds on the tributes.
I think the modern 112 is a better user. Its edge has way better cutting geometry and its older predecessors and 420HC will take a thinner, sharper edge than 440C in my experience. The Micarta scales were a winner, though!
Nothing wrong with an original 112. One of my favorites.
I started using them around d 75 or 76, and never had obvious issues, especially after I figured out that whole sharpening thing....
So what if someone bought a vintage squared micarta 112:: and either had that original blade sent to factory to have an edge 2000 put on it .. or a brand new blade installed with edge 2000? Best of both worlds?
It'd probably be pretty awesome.
I have a 2 dot that I sent in for spa treatment a year or so ago. I asked them to put the modern edge on it, and I've been very happy with it.
Yeah, that would make a really nice user. The 2-dot that Buck restored for me had wood scales, but other than that, it fits that scenario.
In my opinion there's not a lot of difference between the old knives and the new knives from a durability standpoint. Once you get beyond things like the 110 change from fiber, to brass, to stainless spring holders, a lot of the changes over the years have been made to improve the manufacturing process.
I've never used 440-c to have any real experience with it over 420 but Edge 2000 is definitely easier to sharpen. Flat frame vs radiused is probably a bigger factor. I think the S30V drop point blade makes the best user (or S35VN!!) but no early 112's had them. It was a fairly big deal at Buck to radius the 110 and 112..Five different varieties were taken to the Blade Show to get feedback. I 'think' Chuck Buck thought the flat frame gave a more secure grip. If you really like 440-c at the 35th there was a build out Koa for only $100.00 with the LE blade 2 line tang stamp. They went quick but are out there.
As far as practical usage of the Original and early 112 versions.. was there any features less desired and later improved , that make buying such an early 112 as a daily user a not worth while purchase and they’re better as display only? I like the micarta scales on those early 112 and don’t wanna spend the hundreds on the tributes.
Just a thought.... If you want an original 112, then go for one. The originals have a brass rear spacer.
The Tributes have a stainless rear spacer... Just sayin...
One exclusive feature the old 112s have is the whole nostalgia thing going on. :)
