Yes, I can force the lock pin forther into the blade wedge to eliminate the play.
I have cleaned the rails were the pin rides and lubed them. I first used Hoppe's No. 9 oil with no results. I the applies a little Finish Line Teflon grease and that didn't help either.
Would it be posible that the springs on this knife are to weak?
Are we talking about a lot of play? Does the blade move or knock or rattle when shaken? Does the blade move a little when using force to cut something or when applying pressure to the spine? Or is there just the tiniest perceptible movement when you grab the blade tightly and really torque it up and down?
I can detect a tiny amount of movement in Axis lock Benchmades when I really give it a gorilla grip torquing up and down. The movement is very tiny and less than I've noticed with virtually every knife I've owned with back locks. But if it's more than a tiny amount of movement under extreme force, either return the knife for replacement/refund or send it to Benchmade for repair/replacement.
The blade has no lateral play. All the play is "angular" very similar to the type of play you find on a back lock. That's why I don't like back locks.
Maybe it needs a little break-in.
FWIW.. a new 484-1 arrived in the mail to me yesterday and it is rock-solid. No blade play in any direction, centered, with symmetrical grinds. Couldn't ask for more... -there's a tiny bit of grittiness to the deployment (to be expected) ... that will disappear in the coming days (with constant play!)![]()
