Vertical blade play???
AR fan
BANNED
Just bought a 110, used, it seemed tight. When I got home I started to clean and lube, sharpen it. That's when I noticed that the blade is loose on the pivot. The movement isn't side to side though, it's up and down,(vertical). I haven't seen or heard of this type of wear before.
Will the people at Buck fix this? Has anyone seen this type of wear?
Its hard to know if what you see on that knife is normal or too much vertical play. If you feel the lock integrity might be compromised, it would be best to send it in just in case.
So it wont be a waste of your time to send it in, (in case we find that nothings wrong with it), I will have the knife cleaned/buffed and sharpened no charge. :)
Just make sure you send it to Buck's Idaho address, and put my name on the outside of the box os it comes directly to me.
Hope this helps.
Wow, talk about customer service. Thanks Joe, I sure appreciate it.
Once I felt it move I knew where to look, I looked closely and you can see the blade move. So I'm going to take you up on your offer and send it in Mon. or Tues.
