So last weekend I decided I would try my hand at building my own forge. I was tired of my thinner knives sagging in my horizontal forge as well as the lack of space. So why not build a larger, vertical forge? (I am pretty new to this whole knifemaking/blacksmithing thing so constructive criticism is welcomed) The knives would be straightened by gravity and I could also evenly heat larger blades like machetes. I plan on this forge being used primarily for heat treating. most of the materials I used were available at the local hardware store. I used two Ron Reil style burners consisting of a 1 1/2"-3/4" inch bell reducer, 3/4" tube, 3/4"-1" bell reducer as a flare. the jet hole is about 0.05". For the container I used a 30 Lb propane tank. The burners are connected by a series of 3/8" pipe and connectors to a Mr. Heater 0-20 psi regulator.
Pipe layout
Burners connected to regulator
Top cut off of the tank
At this point I cut out two holes just big enough for the shaft of the burners to fit through
I tested the burners at this point (with the paint on, I know. Smart huh?) there seemed to be very little burn going on inside of the tank and there was a large column of fire coming out of the top of the tank. I figured this meant that there wasn't enough oxygen inside of the tank for the burners to have an intense flame. No pictures of the test, sorry. I thought about cutting one hole in the side of the tank to let in more air, the problem i saw with that was that one burner might receive more air than the other.
So to remedy this I cut two holes to the side, but not quite perpendicular to the burners. Say... 45 degrees..ish
The extra air flow definitely helped with the burn
To regulate the airflow I made a track out of some grooved horse shoe bar stock. Then using the propane tank as an anvil of sorts I curved two pieces of a lawnmower blade to fit in the tracks. I drilled and tapped these curved pieces so I could use set screws to hold them in place. I then welded and assembled the track onto the tank.
Now all that is left to do is insulate it. I was thinking about using that wool type material. This is my first time doing anything like this and I know there are a few different types, so is there anything that you guys have found that works particularly well? I have next to no idea what I should be looking for or where to find it so any advice would be greatly appreciated.
Thanks for looking, let me know what you think.
Trogdorr
Pipe layout
Trogdorr
