I have a square wheel 2x72 with a 9 inch platen and a table. I have to remove the table to expose the full platen but when I grind vertical with any knife larger than 10-12 inches for things like vertical grinding the flats the upper or lower guide wheels will not let the blade sit flat on the platen as they sit just slightly further forward to allow a very small gap between the platen and belt back.Is this a common issue with 4 wheel design (which I love for everything else)? Or am I missing something about how to use a square wheel properly for this purpose? I can grind horizontal with no issue with this setup but I typically like to switch back and forth between horizontal and vertical for the flats.
