What causes vertical play on Buck lock back under hard use and does it get worse over time?
I've been using my Buck knives harder in the past few years, especially with respect to cutting brush and small limbs on my property and in making wood shavings for camp fires. A big part of this has been my more recent exposure to Opinel knives, whose lock mechanism seems pretty impervious to any hard use I've dished out. But I've noticed some of my Bucks developing some vertical movement under this sort of hard use.
Typical "hard use" entails push cutting through a branch or sapling. Sometimes I use a bend and slice method. Other times I just use a slicing push type of cut. In most situations, it's with a good deal of force.
I typically keep my thumb on the back of the knife, near the joint. When doing this with my Bucks, I can feel the lock bar move during peak force. Obviously, there is no danger of the knife folding, but something is moving. I don't understand what exactly is happening and am concerned of the play getting worse.
Here's a nice picture of the Buck locking mechanism laid bare to see. (Thanks Robotech!)
Judging from this picture, there appears to be a slight angle to the vertical interface between the lock bar and the blade. My conjecture is that with enough upward force on the blade, there is enough force on the front face of the lock bar that the lock bar is momentarily moved up just a bit.
Alternatively, the movement I'm feeling in my thumb might be explained in some movement in either the blade pivot or the lock bar pivot.
Or maybe a bit of all of the above?
The real question here is whether or not I'm killing my Bucks using them this hard? I'm fearing that this sort of hard work is deforming the front vertical face of the lock bar and that, over time, this will lead to even more vertical play in the blade.
Any thoughts and guidance?
