- Oct 23, 2010
I have 3 American lawmen with the tri-ad lock, and all three of them have some vertical blade play. Is this a common thing with the tri-ad lock? Also can it be fixed?
I`ve had 1 of the original versions (with liners), and have 1 now without. Both lockup solid with no play in any direction. I`ve had 2 of the new recon1`s with the triad lock and both those were solid as well.
You have 3 with vertical play, that would lead me to believe that there might be a bad run of them. I would contact CS customer service and let them help. I`ve had 1 dealing with them last year, and they were more than happy to help, and replace my knife.
I`m not aware of any remedy that would stop vertical play. Those triad locks are built to wear in as time goes by too, so maybe some knifesterbation is in order.
Does the Triad Lock suffer from the same tendencies of some lockback knives where there is inherent, miniscule veritcal play under pressure?
Either what MikeC said or contact Andrew Demko himself, the inventor of the Tri-Ad lock. I'm sure he will be very interested in your problem and might be able to help you out. His username is DemkoKnives.
Guys,
also see this response by Andrew to another member's similar problem in another thread:
http://www.bladeforums.com/forums/showpost.php?p=9124839&postcount=18
Does the Triad Lock suffer from the same tendencies of some lockback knives where there is inherent, miniscule vertical play under pressure?
