- Mar 7, 2014
I received this knife 8 or 10 years ago. It's a Winchester Moose knife. It's a beautiful knife but the clip point blade had an extremely heavy pull at both half stop and full stop. Is there any way to lighten up?
I have used this method as well with good results. I find that resistance to getting started is often caused by not having any transitional curvature from the fully closed position (this is a good thing on the other side, when the knife is fully open but is a problem on the kick side especially with blades that have nailmarks that sit low in the frame).The only way I have been able to lessen the pull on nailbreakers is to soften the corners of the tang with files. It doesn't soften the spring strength, just the beginning pull out of the well.
Also worth a try leaving the blades out at half stop for a few days to stress the springs and see if the resulting slight metal fatigue helps at all. Its a great price if it works.
edit. kvaughn beat me to the post.
I believe to have any effect, the blades would have to be left at either 1/4 or 3/4 open.
If the knife has half stops as you say, the springs would be under little if any tension at halfway.
