1) One of the largest cutting jobs I have to do is slicing up cardboard boxes -- fairly large boxes, but not immense. I could fit inside some of the larger ones, and I'm not tiny. So it's probably fifteen or twenty feet of cutting for each box, maximum. Now, I've been using my G-10 Spyderedge Harpy to slice them up: push cuts, only sawing when I'm starting a push cut.
Several of my co-workers have told me that this (using a knife instead of a razor or a saw) will wreck the blade. I can't imagine how; I've noticed that the blade gets hot from the friction, after a while (but not too hot to touch). I'm sure that after a bit it'll get dull, but I've got a 204, and if you don't need to sharpen your knife occasionally, you might not be using it enough.
I've probably gone through twenty of the above boxes in the past two days, and I haven't noticed a change in the performance.
So you guys tell me: am I using the knife too hard? Normal use or ridiculous abuse?
2) The "Spyderdrop" opening; is this destructive to the stop pin or the stop sleeve or whatever you call it? I know that some people <coughchrisreevecough> absolutely despise it when people flick open a knife, and I can see how that would be very hard on the stop pin.
I don't see how the drop would be any different, since it seems like the same opening method, only reversed.
But then I see that /Sal/ does it, and I hear that a lot of BFers do, so maybe it's not harmful.
Someone help me out?
