Allen, I brought my Vesuvius to the office today so that I could have it in front of me while I anwered your point of concern.
I can see no sign of any ball bearing detente or any other trick method of holding it closed. The pressure of the liner that also contains the Compression Lock piece that wedges between the tang and the stop pin rides against the closed blade and that, in combination with a properly adjusted pivot screw gives a significant amount of resistance to opening unless you are trying to open it. Yet the pivot is loose enough that, when I release the lock with the knife held parallel to the floor, edge side down, the blade falls about halfway closed. This is the perfect amount for me, as I don't care to have it close any further and risk cutting my fingers. It can also be openned with a "Spyderco Drop", the method whereby you pinmch the hole beteen your thumb anf forefinger and give the knife a shake, letting the inertia of the hilt open it for you. I am secure enough with it that I have not made the effort to cange it to tip down carry, my usual method, which I find more secure.
