- Sep 27, 2004
Hello,
Will be going VFD very soon and look at options, as always. Have a single phase 1.5hp right now and three step pulley system.
Reason for question is I have found a 3hp Baldor 1750 motor for $50 locally which seems a steal. Here's a pic of specs:
I have access to normal home 220 in my shop so no problems there.
I am planning to skimp and add filters to one of the chinese VFDs. I realize a KBAC-27D is probably the "proper" long term solution here but sometimes money talks.
At that point I had been planning for a ~2hp motor as I know I dont need more than that. I had planned on getting this VFD:
https://www.ebay.com/itm/390919779712?38280
I'm a bit concerned going for a 3hp chinese VFD and maxing it out with this 3hp motor. I was planning on this VFD with a 2hp motor to give me some breathing room on a less quality VFD.
That being said, I will RARELY use the full 3hp of this motor. I was using my 2hp wired 110 for years and never really noticed losing all that HP, either.
Am I right that pushing the limit of a VFD would really only occur if I was drawing the max amps and such from it? IE running my 3HP at max rate and leaning into the belt with a big bar of steel type application? I could always go to the 4hp version here for $40 more https://www.ebay.com/itm/313182985703?5384499
Alternatively I'll just keep motor searching for a 1.5-2hp.
Other than the recommended 1750rpm and the HP rating, anything else I need to worry about on the motor beyond it being three phase?
Lastly, in my conversion from step pulleys am I seeing that I lose the pulley/belt altogether and somehow mount the drive wheel directly to my motor? I have a 4" rear drive wheel on my grinder that attaches to that 3 step pulley on the other side right now.
Much appreciated! I know bits and pieces of this have been covered over the years but specific applications are hard to gauge as I'm not a real expert in how these things are normally set up and/or converted.
