I would like to know the best recommended VFD to run a 3hp 3ph motor from 1ph 240v
The KBAC29 only drives the 3hp motor up to only 2hp of it's potential off 1ph 240v which is unfortunate because it's such a nice, clean, easy, vfd setup.
The VFD setup will drive a 3hp 1720 rpm motor on a 14×40 engine lathe as well as another 3hp 1720 rpm motor on a belt grinder. The lathe has a SPIN OFF chuck, so it CAN'T/SHOULDN'T brake/stop fast or it'll spin off and throw a 50 pound steel chuck at me.
The gears all work on the lathe, so full power at less than full rpm isn't crucial as long as it's full power at 1720rpm and double 3640 rpm, but full power at less than full rpm on the belt grinder will make a difference (sensorless vectoring?)
Need to be able to DOUBLE the 1720 motor rpms (I bought 1720's for their 4 poles of torque vs weaker 2 poles in the 3640rpm motors)
I have a discontinued TECO Jnev 2hp on my mill which is alright.
I have read sketchy things about the TECO L510's. The N'3 are another $100 but are they much more dependable? ...
Thanks.
Thanks.
