Hi,
I decided to go with a VFD for my KMG grinder and direct drive over the 3 poolies stock system I’m using right now.
Here is what I decided to go with:
VFD: KBAC - 27D 2.0 HP, 6.7A, 230 VAC 3ø Output,
MOTOR: 2 hp, 230V, 17xx rpm, 3phase, TEFC, 56C frame. Didn’t yet decided on brand.
So here are my dilemmas.
1. There are a bunch of options listed for the VFD. From KB website:
Options:
a. On/Off AC Line Switch,
b. Forward-Stop-Reverse Switch,
c. Run-Stop-Jog Switch,
d. Signal Isolator with Auto/Manual Switch,
e. Class “A” (CE) RFI Filter and
d. Liquidtight Fittings.
Do I need any of this accessories and if yes which and why please ? What are the
minimum options to have in your oppinion?
2. What brand motor should I go with? Is something like Leeson, Baldor ? Could you give me a brand and model that works well with your setup?
Since I will double the speed of the motor through some jumpers in the VFD, I wonder if less expensive motors would be able to cope with this.
Are there any other specific requirements on the motor that I need to be aware of when choosing one?
3. Motor shaft diameter 5/8”, keyed. Is this what I need?
4. Where to buy? Good deals.
Thanks again,
Constantin
Options:
Thanks again,
Constantin
