- Feb 5, 2013
I'm shopping for VFD to start a grinder build.
I only have 110v, can't afford a KBAC-27D, $357 [$375 w/ power switch].
I have decent 1hp 3 phase TEFC motor - room to upgrade to a 1.5 or 2hp motor later would be nice but not critical.
Getting one with an unsealed enclosure cuts the cost way down - but only if I don't fry it.
I'm considering making a DIY enclosure for an IP-20 rated model, or would an IP-50 be OK as-is?
I'll be putting the grinder on a cart so I can use it mostly outside, so remotely mounting the VFD to protect it isn't really an option.
I don't have any experience with VFDs. I don't have a sense how much heat they put out, or know if I'm asking the right questions, etc.
Here's the one I hope will work. I know some people have this VFD - comes as a standard option on Tru Grit disk sanders...
KBMA-24D
$167
1hp IP-50
Is the IP-50 enclosure enough protection for a grinder? Maybe sanders just put out less dust?
What about just sealing the enclosure with a bit of foam tape or silicone - Would heat become an issue?
I've also been looking at these two...
KBAC-24D
$238, $254 when you add the power switch.
1hp NEMA 4x
The price is pushing it, but it won't fry. Unlike the KBMA series that has AC power switch, this has run/stop switch, with hole for an accessory power switch.
KBDF-27D
$220
1.5/2hp IP-20
It's the unprotected, digital interface sibling to the often recommended KBAC-27D.
Would be great if I can keep it from burning up - leaves room for a future motor upgrades.
I'm picturing an outer enclosure with a cutout routed out so the panel exposed, with a foam gasket around it. Again, what about heat? I could mount additional controls, but not sure I gain much for the expense since the front panel looks sealed enough.
What about just adding filters? How effective is that really?
I'm steering clear of the few budget imports that take 110v because I haven't found any positive reports. I'm also put off by sellers claiming different specs, like as much as 4hp on 110v. There are also some other options, like the 1.5hp KBVF-26D for $191. It needs a complete enclosure added and all the controls, would end up being as much as the KBDF-27D. WEG has one 110v model but it is more expensive that the KB near-equivalent.
I'm open to any advice, would really like to hear from anyone who has made their own enclosures. I'm sure it's been discussed but only found page after page of the count's standard reply when searching (mentions all the keywords I thought to try).
Thanks
KBMA-24D
$167
1hp IP-50
KBAC-24D
1hp NEMA 4x
KBDF-27D
$220
1.5/2hp IP-20
Thanks
