Gentlemen,
I come humbly before you for some help troubleshooting my KBAC-27D VFD installation.
I have been in the process of setting up my KMG, and this morning was supposed to be the final step... installation/wiring of the VFD.
I am running THIS 2-hp motor that I purchased from Grizzly. It is a dual-voltage (230v/460v), 3600rpm unit. The first thing I did was rewire the motor for 230v as it came prewired for 460v. Below is a photo of the wiring diagram on the motor.
I wired it up exactly as shown on the "LOW VOLTAGE" side of the diagram.
I purchased a KB Electronics KBAC-27D VFD to drive this motor. I ran my wires from the motor to the "MOTOR" terminal screws on the VFD. I also wired the "AC Line" wires to a 220V circuit. Below is a picture of the wires inside the VFD.
I set all the jumpers as recommended in the manual (see picture below):
Jumper Settings
J1 230v
J2 2HP
J3 Automatic Ride-Through
J4 1X Rated RPM
J5 60Hz
J6 Fixed Boost
J7 Regenerative Braking
J8 "Run" Output Relay
J9 Normally Open Stop Contact
J10 Constant Torque
J11 Inverter Duty Rated Motor
So when I finally went to start everything up and connected power to the VFD (plugged in the 230V cord), the VFD powers up and I get a green "power" LED and a slow-blinking red "status" LED. Page 22 of VFD manual says "slow flash red" = short circuit.
So apparently I have a short circuit somewhere. So I re-checked my motor wiring... looks good. I test my wiring from the VFD to the motor... no shorts that I can find. I check the motor wires individually to see if there is a short somewhere in the motor (based on the wiring diagram below)... everything seems to check.
So... anyone have any ideas why the VFD is telling me "short circuit"? Any help would be appreciated. Let me know if I can provide any additional info.
Erin
Jumper Settings
J1 230v
J2 2HP
J4 1X Rated RPM
J5 60Hz
J6 Fixed Boost
J10 Constant Torque
Erin
