So I got my grinder set up today. I have a 1725 RPM 3 ph 2 hp 60 Hz motor and a KBAC 27-D VFD with for/stop/rev and start/stop switches with 220V. We ran a 10/3 SOOW wire from the 220 outlet from the back of our back building to where I can run the grinder. It was a 30 ft long extension that my dad wired. We tested the outlet and it works.
We wired the motor to the VFD using the low voltage specs (T1 & T7, T2 & T8, T3 & T9, and T4, T5, T6 together). The ony thing I changed from factory settings on the KBAC was changing the jumper from 110 to 220V and changing the max speed to 2x from 1x. It was already set on 60 Hz. The 220 V outlet we have is a 10-30 outlet. The wire from the VFD to the outlet is also 10/3 SOOW wire.
When I plugged it in, the power light came on to green and the status light flashed quickly between red and yellow. According to the manual it is "undervoltage". I haven't messed with it since, just unplugged it as I went to supper with my wife.
Here is a picture (not very good) of the panel on the motor. Any help would be greatly appreciated.
