Mine is a FVR-C9S made by Fuji
6.4 amp at 3 phase 0-100 Hz rated for two full HP from 220 input.
thinking about you wanting a 6hp rated unit..
you may know this anyway but the higher the hp rating you go the higher the price (by a lot) for these babies
when I bought mine it was just over $300.00 if I recall.
you just have to think about how much HP you'll be using at one time?
I think for me I'd go with two 2 hp units instead of one 6hp jobbie, because, I'm not going to run more than
2 motors 3 ph at a time anyway. and I'd have the
two just in case I blow one up as a back up if needed..
remember the shop-smith 5 or what ever tools in one??
It's like, if your one motor runs your whole shop and it bites the dust nothing now works, the whole shop is down..
I might mention the switch you get, does not have to be very heavy, where
the amp rating is low on each leg of the 3 ph..for safety I would set up a switch on each motor regardless of plugs and such right were you can get at it easily. hard wiring keep wiring out of the way too. just 2 cents for some common since
to recap on my breaker,, the only breaker I use, is on the 220 end right out of my sub panel that way you are sure there is no power to anything it supplies if shut off,
if I'm not using the motors the VFD does not have to be on anyway so I just trip the braker.
